Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 47
    28th July 2018
    354
    Default Custom exhaust opinions ?
    Just been to see the lad who is going to make my custom exhaust
    He has recommended 3 inch turbo to cat and then 2.5 cat back non res just the rear silencer
    He says that will avoid the drone associated with
    Full 3 inch turbo back decat system produce
    Just wondering what people reckon ?
    All in for half cash half card he wants 720 for 3 inch turbo back with an interchangeable magnex sport cat/decat non res just the rear silencer and an enlarged vxr style tip
    He said he will do it a touch cheaper if I'm happy with the 2.5 inch cat back section
    He reckons the 2.5 cat back won't hold it back
    Edit
    So that's why some of my posts get edited every now and then
    Thought I was going crazy lol
    Was not really promoting merely linking his work so people could give an opinion on the quality of it
    But if that's the forum rules I guess it's just tuff thanks for at least letting me know this time whoever the moderator was
    2009 Astra H Vxr arden blue standard for now but with mtc top hat and crossover delete and ramair filter
    28th July 2018
    354
    Pic of the tip He has for me I have seen a cobra one recently and his is definitely bigger it completely fills the cut out
    20th January 2014
    2,153
    If it were me, I'd be looking for a resonated 3" turbo-back all the way through. Resonated should inhibit any drone
    With your signature stage hints, get it done once, get it done right.
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    28th July 2018
    354
    Thanks for that mate exactly what I was thinking said to the guy I can always add a 2nd silencer at a later date
    Think he just wanted the easier to make and install 2.5 but he did say if I wanted the 3 inch system he was happy to do it
    17,899
    Yes 2 silencer true 3" system.
    The centre resonator will cancel out the drone.
    The Red Baron... Deathace's Avatar
    25th May 2011
    6,964
    I bought the Blue Flame system because it was 3 inch all the way and I have modular options with it.
    Res/Non-Res mid sections (non-res does not drone at higher revs/speeds and res section makes it almost quiet inside)
    200 Cell Cat/Decat section (just unbolt 2 bolts and slide the cat out and slide the decat pipe in and bolt up)
    Full sized tip just fills the rear diffuser perfectly (pictured)
    Unfortunately BF only made a small run of the full systems and all told it was about £1300 for all the options compared to other manufacturers offerings but that was worth it for being able to mix and match options for road/track and know it all fits perfectly.
    I would recommend you get them to make it modular at 3" and then you can buy other parts you need as you need rather than it all welded up and you have to buy whole replacement sections.
    The above pic is when I bought it, I purchased the non res mid section and the decat sections later.
    Russ
    28th July 2018
    354
    Thank you very much pal I will show the builder your post and see what he says
    Really appreciate your reply would you recommend res or non res in your opinion i want noise without a doubt but don't want it to be unbearable
    He has offered to add the centre silencer at later date
    I just think if I go res i will regret it and want non res
    25th May 2011
    6,964
    I would gauge on what he is going to do with the rear box as you can see the blue flame one is fairly hefty to knock out some of the noise which is why I went with the non-res additional pipe and haven't changed it back since. If he is using a smaller rear box then I guess having the mid res box may not be a problem but my gut feeling is you will still want non-res so go with that and buy a res later if you have to.
    Russ
    28th July 2018
    354
    Top bloke thanks for that non res it is can't wait just got to get stem seals done by my mate at vauxhall 1st not filling a brand new exhaust full of oil and carbon lol
    17,899
    I'd have loved a blueflame. Shame about the limited availability and price.
