Results 1 to 10 of 12
    VXRed blooded Rksmith's Avatar
    15th December 2016
    459
    Default oscillating boost pressure
    Can anybody set a good insight of what the above title means. And if possible how to cure it as I maybe suffering from this issue
    Thanks.
    17,899
    Oscillation by definition;
    1.
    movement back and forth in a regular rhythm.
    "the natural oscillation of a spring"
    synonyms: swinging, swing, swaying, swinging from side to side, swinging backwards and forwards, swinging back and forth, swinging to and fro, vibration More
    2.
    PHYSICS
    regular variation in magnitude or position about a central point, especially of an electric current or voltage.
    "electromagnetic oscillations"
    So in the case of a turbo I'd say it's basically a term for irregular boost pressure.
    15th December 2016
    459
    Yeah makes sense as mine seems to have boost when accelerating ( a little) then doesn’t then picks up slightly at the end a lot of flat spots if your like without peaking gradually gets there but then your out of revs.
    What would you say on these Vxr’s could cuz that?
    17,899
    Anything that regulates the boost really. From maf sensors to actuators from bcs to the turbo itself. Need to start eliminating 1 by 1.
    17,899
    Or could be intake issue.
    15th December 2016
    459
    Oh great square 1 again thought I was onto something then see how would you check the actuator to see if it’s not gone weak?
    17,899
    Quote Originally Posted by Rksmith View Post
    Pressure test it ideally. Could try blowing into it , sounds daft but if it blows all the way through you've got a duff actuator lol
    15th December 2016
    459
    Okay pressure test sounds good. So what psi should the standard actuator start opening at and what psi to fully open?
    28th July 2018
    354
    10psi
    If it moves before its weak, if moves after 10 it's got too much preload on it
    Mityvac is what you need
    2009 Astra H Vxr arden blue standard for now but with mtc top hat and crossover delete and ramair filter
    15th December 2016
    459
    Quote Originally Posted by Andyb712 View Post
    10psi
    Sound mate. eBay best place for that bud?
