Results 1 to 5 of 5
    VXRed blooded bottlebill's Avatar
    11th September 2015
    264
    Default astra J VXR front brake costs
    hi all. i read that the main dealer price of replacing the front discs and pads is towards £1600. Even though I accept that this is a bargain price for what they have to do to replace the discs and pads (taking the p**s obviously) can anyone explain what the disc assembly is about ?? I am more used to the normal, hub mounted disc, which is probably more like £50. I dont follow what such a complex assembly is all about. There is obviously a good reason for the complex assembly but an explanation would be nice !!
    Luckily my car came with brand new front discs and Brembo pads and a "don't forget to bed them in ". I replaced the rears 6 months ago with 'another' make - reasonable price.
    13th October 2014
    367
    Best place to start might be the original Brembo patent,
    https://patentimages.storage.googlea...40182660A1.pdf
    each disc is made from 53 parts by my counting, many in stainless steel, plus aluminium and steel,
    https://www.bremboparts.com/europe/e.../premium-range
    https://www.bremboparts.com/europe/e...isc/09-B781-13
    Patent source, https://patents.google.com/patent/US20040182660/de
    11th September 2015
    264
    Ta for the info. I have had a quick look at the drawings and they are as I imagined. I will print them off at work on Monday and have a read. I didn't realise the disks themselves were brembo as well. I thought it was just the calipers. Things have moved on since I bought my Triumph Herald in 1974!
    Sent from my G3121 using Tapatalk
    13th October 2014
    367
    Yes, having solid discs just at the front on a Saab 96, seemed sophisticated after drum brakes all round on my first car, a Wolseley 1500.
    A short video about Brembo composite discs.
    https://vimeo.com/167866427
    It amazes me that floating composite discs work at all with the disc able to move relative to the hub, but they seem to work very well.
    11th September 2015
    264
    Good film and answers my question. Thanks again for the info and film
