Results 1 to 10 of 12
Thread: IDS light
    VXRed blooded Robs-se's Avatar
    28th December 2012
    254
    Default IDS light
    On all the time even after changing the suspension. Need some suggestions for curing it or location of the sensor please.
    VXR enough V6spike's Avatar
    18th May 2013
    1,849
    Have you replaced them with like for like mate?
    28th December 2012
    254
    Yep, struts from courtenay genuine Vauxhall’s part and springs from autovaux, light was on before I changed them all, was hoping this would have sorted it.
    18th May 2013
    1,849
    Re check the plugs on the struts and see if any pins are bent.
    Steering angle sensor is on the front NSF or OSF I think. Not sure if this could be the issue.
    You could try a diagnostic program to what’s the issue and maybe turn off and back on again to see if that helps.
    28th December 2012
    254
    Ok mate thanks, I have an idea now of what it could be, think the wire from the shock hasn’t gone into its housing seat properly.
    18th May 2013
    1,849
    Just be careful mate. Don’t go ragging stuff. You know these cars were made of chocolate and break easy
    28th December 2012
    254
    Oh yes, always treat wires carefully, been caught out in the past.
    18th May 2013
    1,849
    I just look at her at stuff breaks
    28th December 2012
    254
    There’s nothing left to break anymore, think I’ve rebuilt it from scratch over the last year.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,714
    Probably broken wiring, have you oc ?
