Results 1 to 10 of 11
    VXRed VXRrich1992's Avatar
    21st October 2017
    55
    Default Best k06 actuator spring (psi)
    Hi what's the best spring to run a k06 actuator at?
    18,467
    I take it you mean the recirc valve? ....
    21st October 2017
    55
    The spring in the turbo actuator some people say 12psi
    18,467
    Erm, lol you seem to misunderstand. You don't run different springs in the actuator you run springs in the recirculation valve, different springs for different boost levels.
    Actuators will have a certain pressure rating which they open up at, and that is the psi difference you're talking about, but there's no running different springs, you'd need a higher pressure opening actuator.
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,409
    You can run different springs with some ie forge or turbo smart.
    18,467
    Quote Originally Posted by andrewt1971 View Post
    First I've heard of it. I thought they were just rated at a specific pressure and that was that.
    VXRacing ahead Andyb712's Avatar
    28th July 2018
    745
    I think you can change springs on some of the uprated actuators
    Emphasis on the key word though (think)
    Sure I remember reading about it somewhere
    18,467
    Like I said I've never heard of it, and I've been around here longer than ........ well ..... (can't think of analogy)
    VXR enough James-89-VXR's Avatar
    6th February 2011
    4,385
    10psi on standard turbo even at stage 3 it's the solenoid that controls the boost really, on a hybrid say 12-14psi with the increased back pressure
    Stage 2 black VXR gone - rabbid tuned Stage 3 303 sold 9/2014
    Now Revo stage 4+ forged Mk2 Focus RS
    21st October 2017
    55
    Just I'm getting the k06 and turbo smart actuator and recirc dunno what psi to go for?
