Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 54
    VXRed Ollie_b163's Avatar
    20th March 2018
    189
    Default Replacing the rear BCS (not removing.)
    Hi all, so recently replaced my front BCS and happy with the difference that was made. Don't think it has ever been changed or certainly not for a very long time based on its condition...
    I also bought a rear one and would like to do that but csnt seem to find it!
    Any info on where it may be etc? All I seem to find is threads on ripping it all out and binning it, which doesn't really answer my question.
    Thanks all
    Sent from my SM-G960F using Tapatalk
    08' Silver Lightning Astra VXR
    VXR enough Ant21's Avatar
    29th September 2013
    1,504
    Its under the inlet manifold from memory. Best way to get it is from underneath and look up the back of the engine, you’ll see the vacuum box and bcs
    20th March 2018
    189
    Might explain why I csnt seem to see much from above. Already have a feeling this is going to be a nightmare to change
    28th July 2018
    354
    Only way your going to do on the street is with drive up ramps
    It's doable with axle stands but risky I wouldn't want to be that far under a car on axle stands
    It's a 10 min job with a proper ramp take it to a garage
    I'd be surprised if they charged more than £20 to do it
    2009 Astra H Vxr arden blue standard for now but with mtc top hat and crossover delete and ramair filter
    29th September 2013
    1,504
    Quote Originally Posted by Ollie_b163 View Post
    It’s not that bad.
    Agree with the below that ramps are preferable, however I changed my vacuum box with the car on stands with no problem. As long as you take the appropriate steps to ensure your car is secure, you’ll be fine.
    Once your car is up in the air, it will only take 10/20 mins.
    28th July 2018
    354
    It’s not that bad.
    Brave bloke if that goes wrong they would be scraping you up with a shovel
    17,899
    I have a very nice pair of ramps for just such a task as this
    20th March 2018
    189
    Yeah il just do it on stands it'll be fine.
    Half tempted to bypass it anyway now I've read into it more but will decide tomorrow.
    17,899
    Keep it on. Asking for trouble messing with the vac system imo. It was engineered that way for a reason.
    20th March 2018
    189
    Although I agree it's there for a reason, (likely prolonging the life of the gearbox), I don't launch cars anyway and having a bit more boost in 2nd gear I doubt will do much harm.
    Have a mate who has been running it bypassed for ages and alot of people seem to do it.
    Seeing as my rear BCS is likely buggered anyway, now is a good time to test it out. If its rubbish il just fit another bcs after the test drive and connect it all up.
