Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    VXR enough Jon1796's Avatar
    24th August 2015
    1,634
    I’d check/change plugs regap 0.7mm poss coils as well. Mines on bluefin and ‘it’s’ rich won’t pass mot on it.
  2. #12
    9th October 2018
    5
    Quote Originally Posted by El1te View Post
    I wondered that when the OP said 300hp as standard.
    I've only ever seen older 2.8 engines with 250-280hp, same as Vectra VXRs of similar age.
    I thought the Insignia VXR has a different head/valves, injectors and turbo compared to earlier versions of the engine.
    Saab 9-3 turbx had 280hp and no VVT
    9-5NG and VXR are exactly the same motor with different tunning 301hp and 300lbft
  3. #13
    10th August 2017
    92
    The last of the saab 95 only came in automatic.
    Theres a massive 30% drivetrain loss thanks to auto and haldex. Post facelift insignia VXRs in automatic only make ~146kw at the wheel uncorrected.
    If afr drops to 9 you might wanna re tune it and watch your egr and knock. As you lean the mixture back.
    On a side note according to the books the last of the saab 95 was rated for 95 octane fuel while the siggy was 98 probably explain the power difference.
    ^^Australian^^
