Results 1 to 10 of 12
    VXRed blooded Rksmith's Avatar
    15th December 2016
    459
    Default Can someone tell me why this happens?
    So can someone tell me what these marks are on my Bonet seem to always get them directly above where my cone filter is situated.
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,195
    Isn't it water spraying up from tyre if you look down from where that is u will see the wheel edge
    15th December 2016
    459
    Quote Originally Posted by COSWORTH View Post
    You think? Didnít think it could get up there lol
    Regional Assistant - South Essex nurburgring24's Avatar
    13th September 2008
    19,921
    Coming out of your brake resivour
    17th July 2013
    1,195
    I have chrome cover on brake resovoir and when and if I have been driving in wet and open bonnet it's covered in spray and so is the underside of the bonnet - I don't have the insulation on bonnet so can see all the spray clearly
    It's also why a lot of master cylinders get rusty on the underside due to the spray of the road
    15th December 2016
    459
    Iíve checked the cap tight as **** but wished I didnít now as the fluid is black should be clear right?
    Yeah looks a bit like salt I suppose when the water drys glad itís nothing really to worry about.
    17th July 2013
    1,195
    Yeah it's defo water spray but get rid of your brake fluid lol needs changing Asap
    15th December 2016
    459
    Okay nice one for that mate much appreciated
    17th July 2013
    1,195
    No problem
    17,899
    You did unscrew the cap to double check the fluid didn't you? Looking at it through the semi clear plastic can be misleading.
