Results 1 to 10 of 20
    15th September 2018
    8
    Default Stage 2 but below standard
    Have a stage 2 turbo hybrid, full decat 3inch cobra exhaust, forge induction kit, breather hose, boost pipes, dump valve, turbosmart recirc, and forge actuator plus stage 2 remap.
    Just got it off the dyno but states 236bhp how is that possible? Had 5 sensors replaced as a rule out but still same problem. Anyone have an idea?
    VXRed Johnnykage's Avatar
    7th August 2018
    95
    Quote Originally Posted by williamstorm View Post
    240 standard and you have upgraded parts and your getting 236 that’s weird pal. Haven’t a clue mate what’s happening with that
    VXRacing ahead Andyb712's Avatar
    28th July 2018
    737
    That is weird
    1st thing I would start with is a compression test to rule out worn rings or a knackered valve seat etc
    But the dump valve might not help in all honesty I'm surprised a few certain members have not burned you at the stake for even mentioning that word
    Tbh vxr online is a bit of an anti dumpvalve bunch
    I nearly bought one myself few weeks till I was convinced otherwise
    Having said that even a dump valve shouldn't be robbing that much power
    15th September 2018
    8
    Quote Originally Posted by Andyb712 View Post
    That is weird
    Im removing it all tomorrow, also if a turbosmart recirc isnt fitted properly ie: not in the groove etc would that play a part? As im starting to wonder if thats actually in correctly.
    15th September 2018
    8
    Spent 600 alone for new sensors maf etc to rule it out.. nightmare
    18,451
    Evidently there's something seriously not clicking here.
    18,451
    That is weird
    There's rhyme and reason for it.
    Not seen a single vxr run right on an oe /hybrid turbo setup with a DV
    15th September 2018
    8
    Its stage 2 hybrid from WG do you think its the dv then remove that completely?
    28th July 2018
    737
    Only other thing is did the actuator get calibrated
    15th September 2018
    8
    But even if its standard forge setup on the acctuatorsurely it wouldnt be dropping to 235bhp? .. its wierd
