Results 1 to 7 of 7
    25th August 2017
    137
    Default Check front indicator light message
    As above really, I've had this message come up on my screen a few times but indicators are all working fine, any ideas what's going on? Could It be a bulb that's about to give up sometime soon, I've checked for loose connections but all seems fine.
    Thanks for any ideas.
    VXRed blooded Robs-se's Avatar
    28th December 2012
    254
    I had this, cleaned the contacts on the bulb holder and seems to be fine now.
    25th August 2017
    137
    Quote Originally Posted by Robs-se View Post
    Cheers mate, looks like it's a bumper off job then, never done that before.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,713
    Just be careful with the holder they can be a bugger they come out with a twist but don’t always go back as nicely.
    25th August 2017
    137
    Cheers mate.
    Is the bumper easy enough to take off? I've not done it before.
    24th August 2015
    1,713
    2 in the archers then give a tap forward, pull out wards to remove from clamp.
    3-4 on slam panel pull and lift to get over bumper watch out for outside air temp sensor wiring and headlight wash pipe then I normally rest on one of those screen wash refill bottles just the right size wouldn’t bother with removing the 4 push in plugs on subframe.
    Then 3 to remove light unit. Just don’t drop it, to unplug carefully pull/push purple locking tab try not to crack it but you can get replacements.
    25th August 2017
    137
    Brilliant, thanks for all the info
