Results 1 to 10 of 10
    Are you VXR enough? ARCTIC MARK's Avatar
    16th August 2011
    852
    Default Problem with Burg
    Had a little blip in the Astra earlier, then about a minute later i lost all acceleration, the car wouldn't do anything and then the battery and oil light came on.
    Pulled over, turned engine off then started her up again and the car seemed to drive normal, didn't boost it.
    Didn't do a pedal test as i just wanted to get the car home, had a quick look under the bonnet, couldn't see anything obvious (i.e. loose pipes etc)
    Que Adams sarcastic response......
    Opel Astra Burg #686, Eibach springs, Bilstein shocks, Whiteline adjustable rear anti roll bar, Turbo smart actuator & recirculation valve, Brembo 4 pot brakes, DNA Performance FMIC, Enlarged top hat & pipework, 3" Turbo back stainless exhaust, 6k AFL's, Smoked side repeaters, Silvatec indicator lamps, Heko wind deflectors, Insignia washer jets, Crossover delete, Piper cross cone filter, SM Tuning Stage 3 - 300BHP / 310ftlb Torque.
    VXRed blooded Andyb712's Avatar
    28th July 2018
    473
    I will fill in for adam as he said the other day get rid and buy another they are only cheap
    28th July 2018
    473
    On a serious note though did you do a pedal test once you got home?
    16th August 2011
    852
    No, I'll do one tomorrow.
    VXRed Ollie_b163's Avatar
    20th March 2018
    193
    Surprised Adam hasn't turned up yet, he's usually faster than this...
    Sent from my SM-G960F using Tapatalk
    08' Silver Lightning Astra VXR
    20th January 2014
    2,163
    Rumour has it, plod was knocking on his door about certain ice white.
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,230
    Plod were probably there to buy some - vvankers
    18,147
    Anybody would think I'm a real tuat round here
    20th January 2014
    2,163
    On the interwebs, you're more virtual than real
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    18,147
    Quote Originally Posted by VeXeR View Post
    This is true ....
