Results 1 to 6 of 6
    9th June 2018
    4
    Exclamation help needed. issues corsa d vxr pressurising coolant
    hi, i have an issue and was wandering if anyone could shed any loght on what may be the cause. car is fully forged. having an issue with coolant pressurising amd boiling over. literally just had head gasket done and head has been skimmed, new water pump, new thermostat, new reservoir cap. cant think what may be the cause? any help would be greatly appreciated. TIA
    28th July 2018
    300
    Given what you have done or had done already I would guess at something has not been done right
    Or one other possibility is you might have defective fan that is not kicking in around 105
    Only other thing I can think of would be the coolant temperature sensor playing up
    They usually have two outputs one for the guage and one for the ecu either one can fail sometimes both i doubt this is causing your issue but it's something to look into
    Most things that can cause this you have already replaced so it's definitely a strange one
    Maybe someone more knowledgeable on the corsa will chime in for you
    2009 Astra H Vxr arden blue standard for now but with mtc top hat and crossover delete and ramair filter
    28th July 2018
    300
    Did you bleed the system when you filled it back up
    With the heater on full and the cap off get the engine hot and the thermostat open it usually takes about 10 mins and you usually have to add more coolant as it bleeds itself all the air pockets make their way back to the header tank
    Are you VXR enough?
    5th March 2016
    807
    Quote Originally Posted by Andyb712 View Post
    I had a garage change my coolant and it was all full I drove home and as I pulled in my drive steam was pouring out and the reservoir was empty, the garage just topped it up didn’t even warm the engine totally useless, I topped it up again no leaks but it was bubbling so I did what someone as already said left the cap off for around 10 to 15 minutes the coolant dropped again, I topped up and fitted cap went for a long drive all was good again.
    I’m sure it’s nothing serious
    23rd May 2013
    2,389
    Lol
    VXRed blooded srea064's Avatar
    22nd September 2015
    365
    Suggest changing the expansion cap (yellow one) for a new one, or even the black one fitted to the Corsa E.
    My last Corsa D started doing this due to the relase valve in the cap sticking, new cap sorted it.
    Cheap thing to try anyway.
    *** Cavalier MK3 SRi 130 > Astra J SRi 2.0 CDTi 160 VX Line and a Corsa D VXR > GTC SRi 1.6T 180 VX Line > Astra GTC VXR 280 > Focus MK3 ST3 250 > Focus MK3 RS and a Corsa E VXR ***
