Results 1 to 10 of 12
    20th January 2014
    2,163
    Default So today I made....
    Ignore the date stamp. Phone was charging while I removed the mold from the vacuum chamber and reinstalled;
    Polyurethane engine mount inserts. Appearance of a hard boiled sweet.
    Poly is still curing in situ so I'll drive it tomorrow.
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
    20th January 2014
    2,163
    Wide angle lens providing some distortion in the images.
    Tomorrow; last job to completely eliminate all notchy feel from the M32 gearbox.
    I think I have the culprit spotted and it's something people haven't mentioned before.
    Running low on raw material, but we'll see how she goes.
    So far;
    Fresh gear oil
    Linkages including under shifter gaiter all lubed
    Short shifter X2
    The Red Baron... Deathace's Avatar
    25th May 2011
    6,964
    Looking good, love the work area it reminds me of how cluttered mine is but you have to use all of the space
    Russ
    20th January 2014
    2,163
    Organised mess. As long as you know where everything is, you're doing great
    20th January 2014
    2,163
    https://imgur.com/3fHyiSX
    Last factor remaining that's likely causing notchy feeling on gear changes. You'll notice that the standard factory bushing on the end of the linkage (rubber inside the nylon) is very soft and has a lot of play.
    Couple that to the transition of gears 1,3,5 to 2,4,6 and there's quite a bit of compression going on, which makes it sloppy as two bushes (one on the 1,3,5 linkage and one on the 2,4,6 linkage) both compress reducing how direct the throw is.
    Hoping I've enough quick curing material left to mod one bush.
    VXRed blooded Andyb712's Avatar
    28th July 2018
    473
    Hope it works for you mate I bought new cables and while it made an improvement still play even in a brand new one so it is a bad design
    20th January 2014
    2,163
    Done just one today so I had a reference to go by;
    Spray of silicone oil as a releasing agent just in case.
    Pipetted in some liquid polyurethane plastic. Allow a few minutes to turn semi-solid.
    Pressed in the nipple on the shifter arm.
    Allow 10 minutes to set.
    Initial check; with the engine off, no real difference.
    Took it out for a drive.
    Gear shift a bit more direct with the poly engine mount in.
    The big news; Gears 1,3,5 much more direct and easy to find. Slop in gear changes to 1/3/5 noticeably reduced. 2/4/6 are definitely sloppy by contrast.
    Mod works!
    I'll be doing the other cable bushing soon.
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,230
    Nice work as usual - even has records to listen to in the workshop ��
    18,147
    What's this about lube and bushes? .....
    20th January 2014
    2,163
    Quote Originally Posted by COSWORTH View Post
    Not mine fortunately. I'd have them all converted to digital files if I had my way.
    Bushes act as a lube.
    Shaving = chaffing
