Results 1 to 10 of 11
    4th October 2018
    8
    Default Pipecross Filter
    Hi guys
    Just fitted a pipecross cone filter, am i the only one that doesnt like the noise? between 2k-3k revs it sounds like the turbo is having an asthma attack!
    That being said i do like the dump valve on gear changes though
    Anyone else feel the same?
    29th September 2018
    4
    I've got the AEM cone, and it sounds absolutely mint. Got a mate who had the pipercross, and switched to the AEM because he wasn't keen on the sound.
    VXRacing ahead Arron D's Avatar
    9th February 2018
    550
    I too have AEM dry cone
    23rd May 2013
    2,388
    They both sound like someone having an asthma attack, only the AEM is slightly quieter.
    VXRed Dec's Avatar
    7th April 2017
    60
    Quote Originally Posted by Tinker_Man View Post
    Hi guys
    Yeah, totally agree mate , I’ve swapped to the AEM & it’s sounds a lot better 🤙..
    6th May 2017
    740
    The only thing I don't like about the pipercross is that it's not loud enough!
    4th October 2018
    8
    glad its not just me then haha, does anyone know what power increase (if any) there is from adding a filter?
    6th May 2017
    740
    Probably 1 or 2bhp if you are lucky. Sound is usually the main reason for fitting them and slightly less restricted airflow. The filter will add power but you will lose a portion of that due to the intake air being warmer than that which enters via the box.
    I had mine on a standard filter for about 2 weeks and it ran like a bag of spanners, noticeable reduction in power, but I've also heard of others who have found the opposite.
    Just don't soak it in oil like some people do!
    4th October 2018
    8
    I've left my filter housing in and just sat the filter on top of it so it still has the cold air feed, plus i thought it didn't matter because the intercooler cools the air down?
    Also just done an experiment;
    Went for a test drive with the OEM filter on and checked the coolant temp which was : 93 degrees
    With the pipecross it was: 92 degrees
    Maybe the increase of airflow helps keep the engine cooler!
    4th October 2018
    8
    Another thing does anyone know how the breather hose is fastened into the engine bay? (the small hose at the rear of the box not the one that goes too turbo)
    cant find a clamp/screw on it? should it be plugged into anything too or left hanging loose?
