Results 1 to 10 of 14
    CapTIN Caveman... tin545's Avatar
    30th June 2008
    11,662
    Default Sick Nurburgring
    Hi guys
    Been a while since Iíve been on here Iím sure theirs plenty of the old guys still hanging about...the Astra is over 10 years old now and Iíve had my first major problem it seems
    The car is making a funny tapping noise when ticking over, Ive had a guy look at the car and he has changed the rocker cover and seals as this was leaking oil if I mind right this was common on the Astra, now heís also changed the coil pack as he thought that could be the problem... gave it a full service...
    Car ran ok for half a day then started the same tapping noise, heís not sure what the actual problem is but has recommended a compression test...Iím hoping someone has experienced the same problem and can point me in the right direction, thanks in advance Mark
    30th June 2008
    11,662
    https://streamable.com/zpwre
    Took this from another thread sounds very like my problem only there was no answer to the problem!!’
    VXRed VXR-Carlos's Avatar
    13th May 2017
    47
    Does the tapping speed up if you rev the engine or just stay the same?
    30th June 2008
    11,662
    I’ll check that out later I can’t mind if it does or not, it will clear for a while sometimes if I restart the car...then it runs a bit funny sounds like a tractor and I get the engine management light comes
    13th May 2017
    47
    Was just a thought...as if it does Iíd of said your tappits were knackered or on the way out. I presume youíve not run it low on oil?
    20th January 2014
    2,143
    Quote Originally Posted by tin545 View Post
    Did you do a pedal test to see what the fault codes are?
    30th June 2008
    11,662
    Bump
    Very intermittent it seems, will drive fine for 5/10 mins then the noise starts again..no fault codes showing and nothing showing up on diagnostics, the guys have suggested a compression test but I was hoping someone would have come across this fault in the past...I’ve found a couple of vids on YouTube that sound exactly the same but they don’t give the fix!!! One guy said it was sheared bolts on the manifold I don’t know
    30th June 2008
    11,662
    So I’m beginning to think it may be the hydraulic lifters
    Can it do any harm doing an engine flush using wynns fluid, I’ve read a few posts suggesting this but I’d rather check and make sure it won’t do any lasting damage or cause a bigger problem
    VXR enough Markpvxr's Avatar
    10th July 2012
    1,157
    Cracked manifold ?
    Loose spark plugs?
    Arden Astra with black bits
    Engine Originally built by wg motorworks blew up after 34 mile so Muni Singh had to sort out his mess 👍🏻
    30th June 2008
    11,662
    Latest
    They have checked out the tappets etc and all is ok, manifold looks ok too
    What else could it be
