Results 1 to 10 of 10
Thread: Kw coilovers?
    Are you VXR enough? T598 Dave's Avatar
    30th April 2009
    896
    Default Kw coilovers?
    I see they sell two sets for the Vectra vxr.
    A set for ids equipped cars which we have, and a set for non ids cars.
    The non ids versions are a lot cheaper, now I’ve seen in the past people going and having these fitted and needing the shock absorber light on the dash turning off.
    Is that because they were supplied the non ids versions?
    Bit confused why there’s two versions at different prices if the light can be turned out.
    Anyone got any ideas, thanks.
    It aint about how hard you hit............ its about how hard you can get hit and keep moving forward!
    VXR enough Jon1796's Avatar
    24th August 2015
    1,535
    More like they replaced the shocks at the same time.
    The only reason the light would come on is a fault or removal of shocks.
    The coils have no cause or effect to put the dash light on.
    1st August 2016
    400
    Vectra VXR estate 07
    20th January 2014
    2,142
    The IDS set come with a box to turn off the IDS yourself, which you can do far cheaper with Tech2 or equivalent.
    30th April 2009
    896
    Quote Originally Posted by VeXeR View Post
    Thanks I think that answers my question as to why they are a couple of hundred more expensive.
    Far cheaper as you say to just have someone turn off the shock absorber fault light.
    24th August 2015
    1,535
    You have ids,they give a box to turn ids off????
    When changing coils have no affect on ids!!!!
    Is there something I don’t get????
    VXR Torque of the Devil vxrossco's Avatar
    16th July 2009
    9,557
    I think you're getting slightly confused Dave's asking about coilovers which are to replace shocks and spring's hence the IDS question
    #1
    24th August 2015
    1,535
    I must put my glasses on more often.
    20th January 2014
    2,142
    Quote Originally Posted by T598 Dave View Post
    Great choice going for KW btw. On a few cars I've driven with them installed, they were excellent.
    Are you VXR enough? andy-'s Avatar
    12th May 2010
    906
    Clever that they do something to turn the IDS system off
    Previous Astra H and Vectra VXR owner.....
