Results 1 to 10 of 15
Thread: CIM replacement
    VXR enough V6spike's Avatar
    18th May 2013
    1,847
    Default CIM replacement
    CIM is goosed but car still runs so I’ll have to replace it. Been an expensive month for the car with all the niggly things going wrong with her at the minute. Spent about £650 already for pissy little bits.
    Anyway. Who has replaced theirs? I need the correct part number and indent letters please.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,675
    You’ve got oc ?
    If it lets you in it’ll tell you part no. When you first look at it.
    Or take covers off written in big type on it.
    24th August 2015
    1,675
    If you can have the car sat a few days or trip to Norwich
    https://www.jccars.co.uk/Vauxhall/Va...rogramming.htm
    18th May 2013
    1,847
    Won’t let me get into it mate. Where exactly do I need to look?
    24th August 2015
    1,675
    Ident no. UY which is mine front left take off top cover turn wheel to left.
    Pic from eBay https://www.ebay.co.uk/itm/NEW-ORIG-...-/263515703865
    18th May 2013
    1,847
    how do i get the top cover off?
    24th August 2015
    1,675
    Turn wheel 90% you’ll see a cap on shroud, knife or small flat head to remove then cross head screw turn 180% to do other side. One underneath in hole torque screw, pull out ignition cover. The stork boots just come out easy enough.
    That’ll give you a look.
    The center sliver trim on dash, ether side pull off, long one p/s very short one d/s it’s on spring clips that’ll let you slide out the leather et cover in front of dash connected to top cover.
    18th May 2013
    1,847
    cheers mate, i take it to remove the CIM its going to steering wheel off job
    24th August 2015
    1,675
    Yeah have you done that yet ?
    18th May 2013
    1,847
    no mate im at work
