Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: CIM replacement
  1. #11
    VXR enough Jon1796's Avatar
    24th August 2015
    1,675
    Sorry ment before. Just remember to take battery off first and go have a coffee/tea/vodka lol
  2. #12
    VXR enough V6spike's Avatar
    18th May 2013
    1,847
    So got the cover of and confirm part number 13204146 UY which is the same as the one you linked.
    I’m guessing steering wheel off also?
  3. #13
    24th August 2015
    1,675
    Yeah disconnect battery wait ten minutes.
    Turn wheel 90% back side now bottom you’ll feel a hole.
    You’ll need a small medium flat screwdriver place in hole(what your trying to find and unclip is airbag retaining spring)
    In picture left/right side you have a rectangle with a bar in it that’s what you have to move with s/d can’t remember in or out wards but when you do air bag should lift forward then turn 180% to do other side. Unclip yellow and pink remove the bag, unclip harness undo bolt. Easy yeah !!!
  4. #14
    18th May 2013
    1,847
    not done it yet, waiting for the CIM. how do i remove the lower cover?
  5. #15
    24th August 2015
    1,675
    Undo the screw in the hole and pull down the adjustment lever.
    Then 13mm nut holds cim in place. Don’t forget to swap ignition barrel over to replacement cim.
