Results 1 to 4 of 4
Thread: Clutch question
    VXRed Robs-se's Avatar
    28th December 2012
    246
    Default Clutch question
    Is it subframe down to replace the clutch on these?
    Are you VXR enough? T598 Dave's Avatar
    30th April 2009
    894
    It would be the easiest way I would say. It's also the way Regal did mine iirc.
    They did a great job, drove in when they opened, by about 12.30 They done the clutch, slave, LSD, 4 wheel alignment check and road test.
    It aint about how hard you hit............ its about how hard you can get hit and keep moving forward!
    VXR enough Jon1796's Avatar
    24th August 2015
    1,396
    They put lsd in as well ???
    30th April 2009
    894
    Yea was an ideal opurtunity to put a wavetrac lsd in the same time
