Results 1 to 10 of 11
    27th February 2016
    121
    Default Timing chain problem?
    Hello Guys,
    i knew, that on previous insignia was problem with timing chain elongation. I have insignia VXR 2014 with 120000km's on dash and my mechanic told me that in ECU was stored code about cam possition sensor for bank 2. I do not have any problem with my car and no any light on dash.
    If i understand well it mean that my chain is also stretched and need to be replaced?
    Thanks a lot
    17th September 2011
    950
    It does. The code will pop up intermittently to begin with, but it only goes one way. The engine will run without issues for a while, only problem is that no one can tell you how long that while is. At some point it will go into limp mode, and by then, it might be too late to do anything about it as the chain might have jumped some teeth.
    Try getting hold of Nick150 on here, he is apparently somewhat of a timing chain wizard!
    27th February 2016
    121
    This is terrible. I assumed, that on facelift insignia 2014 was this problem solved already...
    27th February 2016
    121
    I tried to PM Nick150 so i will see. Or here is someone who know where to bought best kit for this car mentioned by Nick150?
    In fact i thing that on facelift cars will stay this chain for more that 120000km. I just want to be sure that there is no any problem in sensor than in chaing on facelift car.
    9th August 2011
    2,464
    i don't think the type of chain kit matters pal , its the very fact it needs sorting before its too late
    17th September 2011
    950
    They have improved the material of the chains, but it is still basically the same chain, so they might last longer, but I imagine you will still see some failures on facelifts.
    27th February 2016
    121
    Strange is that on this car was completely replaced engine in 58000km's under warranty. So now i have 120000km's so it mean only 60000km's on absolutelly new engine, so for me is strange that chain is streched...
    9th August 2011
    2,464
    I can see why you think so pal but there doesn't seem to be a set mileage that the chains go at , it just happens unfortunately
    17th September 2011
    950
    My car, from 04-2010, made it 120.000 km before they needed replacing. Others have had theirs replaced after 30k km. The new owner of my old car have had them replaced again at 190.000 km... but he was stretching the service intervals, which is a huge no-no!
    27th February 2016
    121
    were there also some another symptoms like higher fuel consumption?
