Results 1 to 10 of 11
Thread: Turkey noise???
    25th April 2018
    86
    Default Turkey noise???
    My car (I think) is making the turkey noise! As far as I can see there are no splits in any of the vac lines and still holding around -26 on Boost gauge on idle, so shouldn’t be any vac leaks. My car has Forge Recirc, pipercross foam cone and crossover delete, I’m not sure if the noise is normal or not and camera does struggle to pick it up but please see below video. I’ve seen you can order the rebuild kits from forge for the recirc as I got no idea how old it is, bought the car with it already fitted.
    https://youtu.be/kDxaHBlQRXg
    27th February 2016
    121
    There is some vac box behind the engine, some black box and inside is some cone which will be damaged. This box is there for lower down boost on 1st an 2nd gear. You can delete this box, just use google and search for it
    25th April 2018
    86
    As far as I know it’s been deleted due to the vac lines, someone who knows more about these cars than me told me it’s been deleted
    17,595
    Idle should be -20hg
    25th April 2018
    86
    I will double check. It does sit around that figure: wouldn’t a VAC leak bring it to 0? Opposed to being a higher number?
    17,595
    When I had a Vac leak in mine it sat at -15. That was with just 1 line popped off.
    25th April 2018
    86
    In terms of the video does it sound normal for forge recirc/crossover deal/pipercross cone or is that the turkey noise?
    17,595
    You can always get some flutter if you suddenly let off. Turkey noise just sounds very audible in a sick way lol
    10th June 2015
    143
    If you delete the vac box what does this do.Does it benefit the performance in any way.
    25th April 2018
    86
    Certainly does flutter but even when driving sensibly. Hardly on boost etc still gets the tututu noise opposed to some I’ve seen on YouTube go more psssh than tututu lol. Just don’t wanna be wearing my turbo!
