Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    9th August 2011
    2,464
    Question anyone actually carried out a haldex service ??
    as above , any advice or how too's ??
    23rd April 2016
    73
    Quote Originally Posted by bembo449 View Post
    A bloke called Carl (evocarlos is his username) has. You can find him on the z22se forum
    9th August 2011
    2,464
    thanks pal , im not too keen on joining a forum just to track the guy down for one thing , seems wrong to me
    VXR enough AJG's Avatar
    10th January 2010
    1,304
    If you have a look on You Tube for Volvo and Haldex; you should get useful vids on how to service both the IV and V. The V is way simpler but there is some confusion about when VX changed from IV to V. A look underneath should let you know.
    9th August 2011
    2,464
    i did have a look pal but the insignia Gen4 unit is different to the Volvo , there is a plate to remove and the filter kit comes with a new gasket for the plate unlike the other Gen4's which jus have a cap over the filter housing , my only concern is the amount of oil required to do the job as I don't want to over / under fill it
    27th February 2016
    121
    For haldex it is about 0.3L, for differential about 0.6l. Both oils are different. Oil for haldex must be filled over a ventilation hose and after that check the level over hole for level checking. For differential there you will fill oil until it will start to flow out from filling hole. Everything you can find easilly on google...
    9th August 2011
    2,464
    hi darry , ive looked several times on google buy I have not yet found anything specific to the Gen fitted to the siggy vxr ?
    27th February 2016
    121
    So which informations do you need? Better will be to contact me on messenger.
    9th August 2011
    2,464
    after yet more time on the net I finally found a detailed how too on the Gen4 but fitted to the saab 9-3 AWD , its a lot less straight forward than other makes who use the Gen4 but here's the thing , even though I now know how too , I looked at my Haldex while in for MOT and could not see where the filter housing was at all , I identified the pump , ECU etc but not the casing where the filter is located
    VXR Nothing comes close moeman's Avatar
    29th April 2007
    26,278
