Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 51
Thread: Wiring diagram
    VXR enough V6spike's Avatar
    18th May 2013
    1,843
    Default Wiring diagram
    Urgently needed for the ABS module. End to end if possible and any voltage values.
    1st August 2016
    441
    It’s the canbus associated with it and the loom you need to check it’s not interrupted
    Vectra VXR estate 07
    VXR enough Jon1796's Avatar
    24th August 2015
    1,640
    Did you buy that software I linked ?
    24th August 2015
    1,640
    I can get some up tomorrow or Thursday up at stupid time tomorrow as of 2 minutes ago !!!
    24th August 2015
    1,640
    Before I dig the Lappy out what’s the problem ?
    18th May 2013
    1,843
    Before I dig the Lappy out whatís the problem ?
    ***** and tech2 not communicating with any ECUs. Had new rad fitted and braided brake lines the other day and it now displays ABS/TC/IDS canít clear any codes. Was suggested that CIM was at fault but replacement showed exactly the same.
    All fuses, accessible looms were multi metred to death and abs looms returned a value as expected to show a signal.
    Some are now say abs module could be the main culprit hence I was looking for a wiring diagram.
    Iím off tomorrow to Wisbech to extract abs pump and module to rule that out.
    24th August 2015
    1,640
    Got one in garage for test.
    If they think it as fault unplug it and test and see what you get.
    Is this your oc as well as other people’s oc/t2 ?
    Can you remember an f/codes ?
    24th August 2015
    1,640
    Right abs gonna be a few pics.
    24th August 2015
    1,640
    Abs picís
    24th August 2015
    1,640
    Abs
