Results 1 to 10 of 12
    VXR enough V6spike's Avatar
    18th May 2013
    1,843
    Default confirmation on the ABS cables please
    I have searched but they just return the part number. looking to see if both of these part numbers are correct and correctly fitted to the car? IDS still fitted.
    Nearside - 13215183 WZ1
    Offside - 13128269 HYY
    would someone mind checking theirs to confirm.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,640
    18th May 2013
    1,843
    Cheers John. Really need someone to physically check theirs for piece of mind
    1st August 2016
    441
    Your numbers look different to mine but then I’ve not had mine confirmed. Plus you need to mention yours is the early one they changed the ids in 06 I think. So my pn might be different to yours, always easy to check with Vauxhall then you can’t go wrong
    Vectra VXR estate 07
    18th May 2013
    1,843
    Your numbers look different to mine but then Iíve not had mine confirmed. Plus you need to mention yours is the early one they changed the ids in 06 I think. So my pn might be different to yours, always easy to check with Vauxhall then you canít go wrong
    Good point. There are few part numbers on ecat24. Itís a bit difficult to know which ones.
    Are you VXR enough?
    14th August 2013
    897
    Quote Originally Posted by V6spike View Post
    Having had a previous problem with my ABS I can confirm that those are the part numbers that I had. Mines a 57 plate
    18th May 2013
    1,843
    Thanks mate. Really appreciate that
    24th August 2015
    1,640
    Have your windows cleared now ???
    18th May 2013
    1,843
    No mate. Got tomorrow off. Rear passenger carpet feels damp but not 100% sure but itís a start. Got new bearing kit. Just waiting for the loom as I canít find my spare
