Results 1 to 10 of 12
    19th February 2017
    15
    Default VXR Spark Plug issues
    Hi, My Vectra c vxr has been remapped by the previous owner. I tried replacing all the plugs with genuine Vauxhall iridium tipped plugs and it spluttered like a pig. I sent them back and got Bosch ones instead and it still spluttered like a pig. I understand now that it is likely to be the gap size. What size should I gap the Bosch plugs to please.
    Cheers Bruce
    VXR enough Woody's Avatar
    16th December 2013
    1,996
    Welcome aboard VxRO mate
    Try speaking to the place that remapped it.
    HTH
    Woody's Vx Ice Addons
    25th August 2017
    118
    Hi mate, the plugs in a mapped vectra should be gapped to 0.7. I use NGK Iridium plugs gapped to 0.7 with no issues. Hope this helps.
    25th August 2017
    118
    It could be a coil pack causing the sputtering.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,529
    As above coils common problem for misfire.
    Having plugs at .7 or 1mm it should run fine mapped or not.
    19th February 2017
    15
    Thanks everyone for your advice
    Are you VXR enough? andy-'s Avatar
    12th May 2010
    906
    I'd avoid the Bosch plus, the NGK or Denso one are the ones these cars liAs said though might be a coil thats gone
    Previous Astra H and Vectra VXR owner.....
    z28 open block surgeon nick150's Avatar
    1st April 2012
    3,494
    I only use the denso plugs now
    They don't need gapping and they fire better
    NOW STAGE 3 BUILT BUY ME POWERED BY SUPERCHIPS.
    INSIGNIA TURBO,INSIGNIA INJECTORS,QUAFE DIF,PADAL CLUTCH,COURTNEY RAD AND INTERCOOLER,3 INCH SYSTEM,BILSTEN B12'S,AP RACING BRAKES,POWERFLEX BUSHES
    VXRed blooded Finn67's Avatar
    4th November 2012
    319
    Kudos lads - the one time I tried Bosch before I was educated she did NOT like them - waste of money as I replaced them with NGK's and she purred like a cat with a huge bowl of cream in it's fat gut!! lol
    19th February 2017
    15
    Help! I was told, don't replace the rear three cause its awkward. I replaced the front three plugs with randomily gapped bosch plugs between 1mm + 0.75mm. it ran fine but still had the misfire under load so I replaced the first coil pack......No different...so I thought, coil 1 pack ok then, Ill put it into coil 2. still the same so I replaced coil pack with other 2nd hand coil pack as car was acting exactly the same under load. I then ordered another 2 Bosch coil packs and gapped the plugs accordingly so that the 3 rear cylinder have brand new packs and double platinum plugs. I still misfire under load.? could it be that I should bite the bullet and replace all the packs? I honestly feel that there is a more sinister issue here...Please tell me because a man shouldn't be replacing 6 x coil packs in one go ?
