Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 41 to 50 of 64
  1. #41
    VXR enough Jon1796's Avatar
    24th August 2015
    1,529
  2. #42
    Are you VXR enough?
    14th August 2013
    871
    Cheers again, just have to work out the actual problem. Got the weekend to have a look so will test out the one way valves etc and try to see if I can see anything wrong with the vacuum pump? Am I correct in thinking that the vacuum pump is 93191598 if so it's an expensive bit of kit. I also had a look at item 29 which is described as Venturi, brake servo unit vacuum pipe, would that be something else that might cause my problems. I'm clutching at straws here!
  3. #43
    24th August 2015
    1,529
    29 breather for rocker cover tucked under that black plate back right.
  4. #44
    24th August 2015
    1,529
    Default Intermittent Solid Brake Pedal?
    Can’t find it a mo back off ventures. Two valves held on with plate. Left one if I remember right leads to servo and pump. Right for rocker cover and fuel vac.
  5. #45
    24th August 2015
    1,529
    Just thinking to myself no.25 if switch faulty won’t turn on pump.......you could try unplugging and playing.
  6. #46
    24th August 2015
    1,529
    While I’m sober Charles pablo escobar sturgeon Facebook vxr he’s normally breaking.
  7. #47
    Are you VXR enough?
    14th August 2013
    871
    Already unplugged and reconnected, no difference.
  8. #48
    24th August 2015
    1,529
    What about multimeter and closing circuit.
  9. #49
    Are you VXR enough?
    14th August 2013
    871
    Ok, One question I have forgotten to ask is what does the vacuum pump sound like when it kicks in. I've no idea what to listen for so a point in the right direction might help a little. It's a strange thing but ever since I got my clutch done a while back I've had a strange sound coming from the drivers side wing area and if it turns out that it's the vacuum pump then I'm onto something, if not then it's another problem. I know some people are going to say why would the pump be connected to the clutch being done, well it's easy the people who fitted my clutch were a bunch of cowboys and they managed to damage other parts of the car so can't rule out the vacuum pump as they were in about the alternator area which I think the vacuum pump must sit in close proximity? I'm waiting for some vacuum piping to arrive but will keep on investigating until then
  10. #50
    24th August 2015
    1,529
    You kinda answered your own question front right noise, stick your head under bumper you can’t miss it......lol
