Results 1 to 7 of 7
Thread: Footwell lights
    4th December 2018
    7
    Default Footwell lights
    Hi only new on this so I hope this is the right place to ask
    This have a corsa vxr 2017 has anyone fitted footwell lights not plug and play ones , would like them to work when you open the car with interior lights thanks
    17,286
    Fitted them to my 58 plate astra. Tapped the feed from the pins which power the main courtesy light so they operate the same.
    4th December 2018
    7
    Thanks is that from the fuse box ? Or from the light itself & hide the wires.
    Stevie
    17,286
    Light itself and hide the wires. Saves faffing about routing to fuse box.
    17,286
    http://www.vxronline.co.uk/forum/sho...ht=Quick+write
    Obviously it's for an astra, but you get the idea.
    VXRed srihaggis's Avatar
    22nd June 2018
    38
    I did the same as Adam, only difference is I soldered the wires to the contact tabs than to just wrap them around.
    4th December 2018
    7
    Ok thanks guys only new to the vxr corsa changed from fn type r , so probs be on again for things , have a pipercross filter coming, by the way can you do anything with the exhaust instead of a change , 2017 model , and thanks again guys for ya help
    Stevie
