Results 1 to 10 of 13
    7th March 2018
    48
    Default Engine vibration
    I would appreciate opinion from members about the following. I had a business trip today. Going there I was kind of late and I've put te car into VXR mode. I was driving 130-135 m/h for about 20-25 miles, engine running at app. 5000 rpm.
    On the return home, last 20 miles I took off the highway, put the car in the VXR mode and drove down the winding mountain road in the 6th gear, engine revving 1500-2500-3000 rpm. Maybe I should have used a lower gear. At the end I started to feel little vibrations, which I assumed were coming from the tyres and the bad road. Turning back to the highway for the last 10 miles, I accelerated to 112 m/h, the engine revving at 4000 rpm. During acceleration car started to tremble much more. After a minute or so the car was vibrating significantly and loudly, so I took off the highway to check tyres. Pressure in the tyres was fine and I continued slowly home on a local road. Arriving home I've put the car in the neutral and revved the engine. It was picking rpm slower than normal and would not go over 4000 rpm. I didn't want to push it. The car has the stage 1 map from Klassen Germany. I believe it's the same map as Courtenay as they are partners. What could be the problem: chains, clutch, gearbox? Bad fuel or water in the fuel? Something else? Is it ok to drive it without pushing it? The car has 42.000 miles. Haldex oil and filter were changed at 29.000 miles. I change oil and filters approx. every 9.000 miles. I don't drive often in the VXR mode. Brake pads are still original and first set of Pirellis made over 25.000 miles. I would appreciate any opinion.
    Sent from my SM-N950F using Tapatalk
    Bardo
    Insignia ST OPC Unlimited
    2016
    3rd September 2015
    417
    I am wondering if reving in netral can go over 3000-4000 ? maybe there is a limitation, don't remember.
    About the vibration, could it be pads/discs that have been used and (over)heated ?
    It happens on brembos after some hard braking, maybe you should give it a clean (especially the holes, use a wire to get into them).
    No warnings ? no other symptoms than vibration ?
    Reving slow only in neutral ? or on the raod too ?
    7th March 2018
    48
    Tried again this morning. The engine revs slowly to 4.000. Maybe it could rev higher on full throttle. Before it would rev briskly to 7.000. Yesterday it started to vibrate during acceleration, while throttling the engine. Not while braking. No warnings on the dash.
    Bardo
    2016
    8th December 2018
    1
    Quote Originally Posted by Bardo View Post
    It sounds like it could be your MAP sensor.
    17th September 2011
    963
    Have the codes read out. If it has gone into limpmode, it will have stored a code.
    7th March 2018
    48
    I took the car to Opel. It turned there was some garbage wrapped around the transmission shaft which I have picked on the road at night. And the low rpm in neutral was just me being to careful/scared to push the pedal! Silly! I have over 1 mill. kms behind me and never had such a case. All the stories of chains, Haldex and clutches just make one crazy.
    Bardo
    2016
    9th August 2011
    2,584
    so the car is back to normal pal ??
    7th March 2018
    48
    Yes, thanks for asking!
    Balanced winter tyres again, checked it today on the highway in the VXR mode, doing 210 km/hour for 25 miles. Already done 1300 miles.
    Bardo
    2016
    7th March 2018
    48
    Just for the info, the problem was in the front brake pads. It happened again last Friday, during spirited driving on a curvy road downhill. I went outside and brakes were smelling heavily. I should have done it first time. It looks like pads were too thin, transferring heat too fast.
    They were around 5 mm thick. Oil was boiling and clamps would not let loose. They lasted 71.000 km. New pads (original) were installed yesterday. I've paid app. GBP 350. With 30% discount! On the central stock for South-east Europe in Budapest they've had only one set. Not in high demand I would say.
    Bardo
    2016
    9th August 2011
    2,584
    you really should have upgraded the pads pal , the stock ones are simply not upto the job of stopping the big fella , I recently fitted EBC redstuff pads , the brakes are waaaaaay better now
