Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    19th December 2018
    6
    Thanks. I will change that.
    I believe its front of back tire, tank side?
    Its -10c here, snow. Nice to change it...
  2. #12
  3. #13
    19th December 2018
    6
    Weather has halted for doing anything for car now. Real feel is -15c so too hard to start fixing now. Tuesday should be around +1c, so Ill wait...
    And thank you.
    I read values again and noticed that at cold start it showed coolant temp over 40c and cat temp 400c. I drove 1km. Started again after 20min break. Now the cat was 50c and coolant 60. Car was at garage, temp about 10c.
    Its vice versa at it should be? I cheked this many times.
    Does my ECU work or is my sensors bad?
    And Im going to chek that FF also.
  4. #14
    VXR enough Jon1796's Avatar
    24th August 2015
    1,714
    Until you start replacing things and you still get same readings then I’d say ecu/map.(could also be app your using)
    It won’t hurt replacing fuel filter if you don’t know when it was last changed.
    I’m going with what you started with 02 sensor replace and see what happens.
  5. #15
    19th December 2018
    6
    Yes. App is also suspect. Cant forget that also.
    Yes, FF is £10. Ill change it anyway. For future. And o2 I already have at home. MAF I will clean and check fuses. Thats the start.
  6. #16
    VXR newbie Gtbloke's Avatar
    7th December 2018
    9
    Stretched timing chains.
  7. #17
    24th August 2015
    1,714
    No not this time.
