Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 51
  1. #21
    VXR enough Jon1796's Avatar
    24th August 2015
    1,634
    Having a blonde moment how the duck do you remove these....
  2. #22
    24th August 2015
    1,634
    Shocks arenít rated for axle weight like springs, thatís why B8ís are the same for the whole vec range.
    The options for aftermarket suspension has been done to death on Vec c let alone on here in the past
    Iíll give you a clue, the details of whatís on mine are in my signature and car diary on vec c
    Think they might as you wouldnít want 1.6 on 3.2 for the weight different follow rate...... talking out me grouse.....lol
  3. #23
    1st August 2016
    440
    Think they might as you wouldn’t want 1.6 on 3.2 for the weight different follow rate...... talking out me grouse.....lol
    I know the technical aspects behind suspension and I have argued that it should be higher to follow the higher rate springs as the axle weight rises but they don’t. Easy to check just find the same part numbers for all shocks, I have found my mates Passat B6 has stiffer B8’s than mine does. I wish the vectra bilsteins were as stiff as it would handle even better
    Vectra VXR estate 07
  4. #24
    Are you VXR enough?
    14th August 2013
    896
    Funny thing, I came across the same problem but mine had already given up the ghost so I just prized them all off from the rear heat shield, I did have some problems with the main exhaust heat shield of which I've purchased another but came across another post which someone had just used a self tapper. I used roofing/racking screws which have a sort of felt/leather padding and re fixed the exhaust heat shield, on a temporary basis. Won't be able to do the same for the rear heat shield as it is straight into the body and not chassis. But they are described as bolts so I assume if they were in good nick you would just screw them off?
  5. #25
    Are you VXR enough?
    14th August 2013
    896
    No replacement ??? They still sell them.
    Or put on the 3.2L shocks about the same weight up front.
    Put on what you prefer.
    Yes, I know they still sell them as I've just had to buy a front pair? What I mean't was that there was no replacement shocks produced by another company that would be a straight swap as everything seems to involve the removal of IDS from the system via tech2 or similar
  6. #26
    VXRed blooded CoolStory's Avatar
    21st July 2018
    458
    So people thought the wishbones on vxrís were different to other spec vectra?
  7. #27
    24th August 2015
    1,634
    Quote Originally Posted by sinbrad View Post
    O.C. Five minutes done.
  8. #28
    Are you VXR enough?
    14th August 2013
    896
    Quote Originally Posted by CoolStory View Post
    So people thought the wishbones on vxr’s were different to other spec vectra?
    Even Vauxhall quote separate part numbers!
    Taken from ecat...
    9 24413016 352052 ARM,ASSY.,FRONT SUSPENSION,RH (WITH BUSH AND BALL JOINT) (EXCEPT OPC,VXR) 1
    9 24413015 352051 ARM,ASSY.,FRONT SUSPENSION,LH (WITH BUSH AND BALL JOINT) (EXCEPT OPC,VXR) 1
    10X 93171448 352319 -KIT,BUSH,DAMPER,FRONT SUSPENSION ARM,REAR 2
    11 24456355 352988 --SCREW,BUSH TO FRONT SUSPENSION ARM 2
    9 13225799 352082 ARM,ASSY.,FRONT SUSPENSION,RH (WITH BUSH AND BALL JOINT) (OPC,VXR) 1
    9 13225798 352081 ARM,ASSY.,FRONT SUSPENSION,LH (WITH BUSH AND BALL JOINT) (OPC,VXR) 1
  9. #29
    24th August 2015
    1,634
    Notice anything!!!
  10. #30
    1st August 2016
    440
    That I was right?
