Results 1 to 7 of 7
    29th December 2018
    7
    Default Soon to be a zafira vxr owner
    Hi I'm Simon I looking at getting a zafira vxr in the next week or so what should I look out for help will much appreciated
    VXR enough AndyM's Avatar
    20th April 2006
    1,012
    Welcome, hope the search goes well.
    Look out for the gearstick movement when 'on' and 'off' the power, and listen for gearbox whine, may need a rebuild. Check for smoke from the exhaust, could be stem seals or turbo. The IDS suspension can be expensive to replace, look for faults, Switch the ignition on (without starting the car) and wait for the needles to sweep, the IDS light should go out. If it stays on, and then goes out after the car is started it's logged a fault which could be intermittant, and stays on after the car is started there is a hard fault. Check all windows go up and down from ALL available switches, the wires in the door looms can break.
    29th December 2018
    7
    Thanks u andym I will keep my eye out for the faults
    VXR enough Woody's Avatar
    16th December 2013
    2,020
    Welcome aboard VxrO mate Hope you find the right motor soon.
    Woody's Vx Ice Addons
    29th December 2018
    7
    Pick my first vxr today love it thanks everyone for the advice
    19th November 2014
    11
    Any pictures Simon?
    29th December 2018
    7
    No not yet can i upload from my 0hone on to here or do I need to upload from pc
