Results 1 to 10 of 10
Thread: Code 123458
    VXRed blooded Rksmith's Avatar
    15th December 2016
    435
    Default Code 123458
    So got this code after changing my vacuum box and put all the vacuum pipes back to its original setup with new silicone ones rather then the delete system.
    As the car was not boosting correctly I thought this may have solved it but still no luck and now have this code. Anybody 96-100% know what this code is thanx.
    VXRacing ahead tye_time's Avatar
    24th February 2017
    609
    Possibly split diaphram on the recirc valve?
    http://www.vxronline.co.uk/forum/sho...836-Error-code
    15th December 2016
    435
    Great Iíve just sold my forge one I had as didnít need it
    As for the BCS is the front one the same as the rear one? As Iíve got a spare one of them
    24th February 2017
    609
    I think the one on the rear might be different, but not too sure!
    15th December 2016
    435
    Yeah just checked slightly different. Iíve also read it could be actuator or turbo itself.
    One thing that annoys me about these cars one code could mean 50 different things.
    VXR enough Jon1796's Avatar
    24th August 2015
    1,535
    Is there a link to these app codes they do my head in
    O.c. T2 easy to understand.
    15th December 2016
    435
    Ay?
    17,637
    124358 used to come up all the time when my vac pipe popped off. It's a common code for an issue with the evacuating boost pressure.
    15th December 2016
    435
    Cheers Adam il give it a look over just in case it has popped off.
    15th December 2016
    435
    Checked pipes all are on.
    Iím getting a bad flutter at low revs sounds like a pipercross filter but Iíve AEM but when I put my foot down to about 3k just a hiss comes from the cone filter any ideas to pinpoint this issue?
