Results 1 to 10 of 13
    VXRed 82Matt's Avatar
    10th December 2018
    71
    Default Aftermarket temp gauge vs hidden menu temp reading
    I bought my car with an already installed water temp gauge. The wire feeds down to the right hand side of the engine as you stand in front of it. Tonight I went Into the 'secret menu' on the head unit and the temp reported there is approx 10 degrees less than the aftermarket (cheap looking) gauge.
    My questions are..
    Are they 2 different places temps can be read from?
    Is my gauge just poo and inaccurate?
    Can I just trust the secret menu reading and stop worrying myself silly.
    Yes I could go out and buy a new gauge but thought I'd get some feedback here first
    Sent from my SM-G965F using Tapatalk
    17,905
    That's a very good question. Do you trust the calibration of the ecu or the reading from an aftermarket gauge. ..... I'd be tempted to side with the menu .... but I dunno
    10th December 2018
    71
    Haha when you say it like that it's almost a no brainer... but I'm holding out for some more feedback on the matter.
    17,905
    It's just i'd be tempted to trust oe equipment over aftermarket as it's normally far better quality if you know what I mean lol.
    Just my 2 cents on the matter anyway
    10th December 2018
    71
    Quick snap taken between the 2 gauges. And yes I believe the -40.0 is not the real outside temp but not far off!
    17,905
    Yuck, that cheap looking BID screen lol
    10th December 2018
    71
    Just to update things guys. So the reason I questioned this was my ching chong gauge read 118 whilst stuck in town traffic on Sunday, jumped out and the (also aftermarket) rad fans were not running so given I've just had a new head gasket I browned my pants there and then.
    Tonight we checked the wiring loom for obvious signs of a problem. Checked the fuses and bridged the relays, one relay made one fan spin fast. The other relay bridge made both spin slow. Not sure when the high speed fan is suppose to kick in and if only one is normal as again it's aftermarket.
    Regardless we knew the fans weren't goosed
    So then happy enough with the above we just left the car running with heaters set to cold and not blowing and 20+ mins later it eventually hit 95 on the cars display when the slow fans kicked in! The other gauge read 120 at this point. The car soon dropped to 90 and the fans stopped. The cycle repeated of course.
    So the gauge or the way in which it was plumped in is just plain dodgy. I'll replace with a quality item and go from there.
    The only questions I'm left with is when is the high speed fan supposed to kick in and why aren't both? AC has been deleted btw
    Long post sorry but no point getting half a story eh
    23rd April 2016
    75
    Not to state the obvious here but the ecu is reading the temp as 80 and not -40
    Forget it i have just re read your post lol
    10th December 2018
    71
    I'm aware that part of the screen is for the ambient outside temp. That sensor isn't there or very broken.
    25th September 2013
    1,083
    just a thought as you have removed A/C the high pressure switch will no longer make a circuit and this is what brings the fan on high to cool a/c condenser, you could try bridging this to see if it brings the fan in on full.
    stage 3
