Results 1 to 10 of 10
Thread: AFL headlights
    VXRed IsOoAvinOne's Avatar
    15th October 2014
    59
    Default AFL headlights
    Hi all, anybody know of any Afl’s that are for sale or where to get some from? Thanks
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,234
    Flea bay or vaux breakers.
    Private ads online as they are now worth more in parts than complete cars.
    18,193
    I presume you know of the hassle to actually get them to work?
    VXRed 82Matt's Avatar
    10th December 2018
    77
    Aren't the bulbs silly money too?
    Sent from my SM-G965F using Tapatalk
    18,193
    65-70 quid for the decent ones.
    VXRacing ahead tye_time's Avatar
    24th February 2017
    634
    I will get bi-xenons at some point, cheaper and less hassle, while looking identical!
    18,193
    Quote Originally Posted by tye_time View Post
    Ah the fraudsters way .......
    15th October 2014
    59
    Hi all. Managed to source some lights with everything needed to fit other than the loom that runs from the rear level sensor on the rear beam to the control module behind the glove box. Anybody any ideas where or who to talk to about getting hold on one?
    Also I’ve retro fitted mine and my mates AFLs recently but just trying to see if I can get my Mrs set working proper.
    14th April 2012
    33
    Quote Originally Posted by IsOoAvinOne View Post
    Hi
    Well if you can manage, it will be easier and cheaper to make the loom yourself, its just 3 wires.
    You buy part n/ 93186708 (the connector and cables for the axle sensor) and then extend the loom to the control module.
    Later i can tell you the wiring diagrams, but its relatively easy to do.
    And by the way, you might be able to help me: how do you get the cables thru the firewall to the UEC?
    That's my struggle, its seems impossible to add more cables to the original grommet.
    14th April 2012
    33
    So the wiring for the leveling sensor is as follows:
    Pin 1 from the level sensor goes to pin 11 on the AFL leveling control module
    Pin 2 goes to pin 10
    Pin 3 goes to pin 7
    Give it a try, you buy the part number I told you about and just extend the wires.
    If you need the plug for the control module, I think it's the same as the window switch and the climate control module, you have to find it used.
    I hope this helps
