Results 1 to 10 of 14
Thread: Vx rip off
    1st January 2014
    116
    Default Vx rip off
    I can't get the cv joint out of the wheel hub trying to fit my new abs sensor the cv joint will not detach it's self from the hub so went to vx to get my self a new cv joint and a hub carrier cv joint was £68 and the hub carrier was £590 and i would have to wait till it gets in to the country has any one had to fit a new one and how much did you pay and where from been told it's a main dealer part only i dont like to fit second hand parts but definitely not paying 600 for a new one
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,391
    I don't see why you need a new upright/hub carrier. Cut through the CV joint as close to the upright as possible, this should allow you to undo the bearing bolts and the remenants of the CV should be small enough to pass through as you remove the bearing assembly.
    1st January 2014
    116
    I got the hub carrier off the car with the end of the cv joint in it it's like the splines are seized together I have put heat on it hit it and put it on a 10 ton press
    1st January 2014
    116
    Need a bigger disc cutter lol
    VXR enough Jon1796's Avatar
    24th August 2015
    1,675
    It’s an Astra plenty of parts in the scrap yard as most parts are the same on any as on most cars.
    24th August 2015
    1,675
    VXRacing ahead tye_time's Avatar
    24th February 2017
    634
    Quote Originally Posted by matthewjones90 View Post
    that is outrageous. haha.
    25th January 2010
    3,391
    There are five different variants of upright fitted to the Astra. As vauxhall went to the trouble of making them I'd be careful about fitting just any.
    1st January 2014
    116
    All back together left it last night in red diesel and out she come quick rub down and back on it went .passenger side was a dream and the two back ones if any one had to get a new hub carrier the 1.9 cdti are the same so I have been told
    18,193
    Red diesel? Are you a farmer? Lol
