Results 1 to 7 of 7
Thread: Crank
    17th January 2019
    4
    Default Crank
    Is the c20let c20xe crank the same as Z20leh please
    18,499
    Not 100% but i'd go out on a limb and say no. I say this cause my local tuner once built a garrett vxr where he swapped the whole bottom end out for the c20 bottom end.
    17th January 2019
    4
    Ok thanks
    25th September 2013
    1,095
    Doubt there close enough, the zlet is close to the vxr one but no oil injector holes for pistons , just get yours reground and larger bearings.
    stage 3
    18,499
    I've read a lot which suggests the let has a stronger crank than the leh.
    17th January 2019
    4
    Will the z20let crank fir the leh then ? I’ve had a price on a re grind and it’s £200 odd quid like
    18,499
    Again I'd doubt it's a direct fit. Can't be much difference in price for a leh and let crank surely??
