Results 1 to 10 of 12
Thread: Boost problem
    VXRed VXRrich1992's Avatar
    21st October 2017
    55
    Default Boost problem
    Hi all I'm hoping someone can help I've got a problem with my vxr it was on the dyno today and for some reason the boost tails out quicker than the standard turbo the car is running a k06 turbo with cut back blades, cross over deleted with aem filter, stage 2 airtec intercooler, top hat and boost pipe, 2.5 turbo back and it only made 260hp and 300ft but the other problem I live in the isle of man so there is only one person on the island that has a dyno.
    VXRacing ahead Andyb712's Avatar
    28th July 2018
    562
    My money is on a worn out actuator unless it was replaced when you had all the work done
    Even the it could be poorly adjusted get a mityvac on it
    10psi is the standard break off pressure but that's for a standard car
    Also that exhaust will hold you back a little if your aiming for big power
    21st October 2017
    55
    Turbosmart 10psi actuator and recirc are about 3 months old and the 2.5" shouldn't hold back that much
    21st October 2017
    55
    Done a mityvac it starts to open at 10psi
    18,193
    Maybe you're getting valve float? A hybrid will sometimes do so with standard valve springs.
    21st October 2017
    55
    He had another on the dyno with the k06 and similar mods and that made 299hp
    18,193
    Still doesn't necessarily mean you're not getting valve float. Every car is different. If all is fine with your turbo system it may be throttle closure. Any warning lights? Codes?
    21st October 2017
    55
    No codes no light just went for a blast over the mountain was pushing 24psi then had a big boost drop now only making 8psi ����
    21st October 2017
    55
    No codes no light just went for a blast over the mountain was pushing 24psi then had a big boost drop now only making 8psi 🤬🤬
    18,193
    24psi is a bit high. Unless it's a temporary over boost spike. There's obviously something in the setup the ecu isn't liking if its shutting off the boost.
