Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
    VXRed azza15's Avatar
    24th May 2018
    64
    Default Loud hiss while on boost
    As the title says I've got an incredibly loud hiss when the car comes onto boost.. I've done a few searches but I'm afraid of wondering into a minefield of could be this could be that..
    The car doesn't feel down on power but it for sure doesn't sound right at all so I'm curious what would be the absolute obvious things to check first and what would I be looking for with them exactly?
    Any help would be greatly appreciated thanks
    VXRed VXR-Carlos's Avatar
    13th May 2017
    60
    Mine makes a loud hiss/whistle as well. It is at the moment. My problem is that the manifold nuts always seem to come loose, just one or two but itís enough to let the exhaust gasses out. Could be the same issue.
    24th May 2018
    64
    Funny you should mention that as I've very recently had to tighten mine again as they were loose enough to be taken off by hand! Definitely made a difference but I still have this hissing sound unfortunately
    13th May 2017
    60
    I had 3 loose this morning, tightened them up and the sound is still there. Checked pipe work and canít find anything obvious. If you happen to find out whatís causing yours Iíd be interested to know.
    VXRacing ahead Andyb712's Avatar
    28th July 2018
    562
    It's probably the fact they have come loose so your gasket has been damaged
    The manifold gasket can be replaced without removing the whole manifold and turbo but you need to remove 4 left side studs aswell as all the nuts to gain enough access to change it
    24th May 2018
    64
    Fingers crossed thatís what it is! Will let you know what I find
    24th May 2018
    64
    Quick update Iíve had the manifold and turbo off, found a hairline crack near the wastegate and the manifold studs were in the wrong way as far as I can tell..
    13th May 2017
    60
    Is that a new mani and then? Was it easy to take off?
    24th May 2018
    64
    The manifold wasn't too difficult to take off at all really but it looks like I need a new one unfortunately(I really should've noticed the crack when I put the downpipe on). I got very very lucky and had all of the manifold bolts come peacefully with non of them shearing the studs which was a huge bonus.
    Other than the manifold bolts it's just things like the oil feed and return pipe to disconnect along with the coolant pipe I had to block off temporarily(still got drenched in coolant). The downpipe and pipework from the airbox and intercooler need to come off too along with the vac line to the recirc valve.
    I had a lot of cleaning to do once it had all come out and I definitely need my valve stem seals doing but after cleaning it all up and sticking a new gasket on it does seem to have quietened it down an awful lot!
    Still unsure on what kind of effect/problem this hairline crack near the wastegate would cause me though so if anyone can shed some light on that I'd appreciate it, will have a new one stuck on soon hopefully.
    24th May 2018
    64
