Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 65
    VXRed Teejayycee's Avatar
    26th February 2019
    30
    Default VXR limp mode with new exhaust?
    Just installed my 3” turbo back straight pipe, unbelievable but when I flatten it and go over 4K revs it jumps into limp mode, I have a delfi laptop and removed the codes but soon as you hit 4-5k it does it again, how can I fully remove the code? Code is emmicions for obvious reasons
    Are you VXR enough?
    5th March 2016
    986
    Quote Originally Posted by Teejayycee View Post
    I said yesterday you will get engine light on if removing the car the car thinks it’s got a car but without it will be running either very lean or very rich u need it mapping if your gonna run without a cat
    26th February 2019
    30
    Will a induction solve it until a map? £300 for a map bro ��
    Are you VXR enough?
    5th March 2016
    986
    Will a induction solve it until a map? £300 for a map bro í*½í¸«
    No mate u will need it mapped a sports cat isn’t a lot more and keeps it legal and sounds just as good
    VXRed blooded Andyb712's Avatar
    28th July 2018
    445
    https://enhanceyourcar.co.uk/product...sensor-spacer/
    This might solve the problem but as said above you need it remapping ideally
    23rd May 2013
    2,450
    Try the spacer mentioned above and put it in the last lambda under the floor of the car.
    The eml light may come on again though (mine did with spacer and sports cat) so you might need to try packing it with wire wool as well if that happens.
    TBH you'd be better flogging the exhaust and just putting the money to a stage 1 remap - you won't have any hassle with spacers/mots, badly fitting aftermarket parts and it'll be arguable as fast real world world driving vs a full stage 3.
    Its just not worth spending thousands to squeeze an extra 20-30 out of the car, especially if its rusting away in front of you.
    26th February 2019
    30
    Still limp mode mate with the lamber? What can I do? Map is 300 quid
    Are you VXR enough?
    5th March 2016
    986
    You need it mapped
    23rd May 2013
    2,450
    Have you tried packing the spacer with wire wool?
    VXR Nothing comes close Tom_Y2K4's Avatar
    3rd August 2009
    24,555
    Answer in the question
    South East Regional Organiser
    PSN: TomFL12
