Results 1 to 10 of 11
    15th August 2016
    63
    Default Tx sportscat and lambda sensors
    Got to pick up my tx sportscat from dpd tomorrow as missed it Friday, I was just thinking is there a place to put the 2 lambda sensors on sportscat downpipe looks like there is but hard to tell from picture, plus when sensors fitted will it bring on the management light or will the management light stay off with the first precat missing, or do I need to get warning light tech 2 deleted, once again thanks for any Info as I'm not the best with the mechanical side of cars
    15th May 2013
    17,928
    There are 2 holes on it for lambdas mate. One for the first where the precat usually is and one post main cat.
    I had one so know
    You will need a 90 degree elbow spacer unless you are having it mapped
    15th August 2016
    63
    I had one so know
    Cheers mate, I'll be having it mapped, is that because it will bring on light and during map they can take light off, the 90 degree elbow spacer were does that go, on sensor were the precat used to be or on secound sensor past the sports cat
    15th May 2013
    17,928
    Past the sports cat mate. Never stick a spacer on the first one!
    VXRed blooded Andyb712's Avatar
    28th July 2018
    449
    Just curious what you running for catback?
    15th August 2016
    63
    Quote Originally Posted by Andyb712 View Post
    Tx sports cat with milteck exghaust
    15th August 2016
    63
    Cheers mate
    28th July 2018
    449
    How do you rate the sound
    And is your miltek res or non res?
    15th August 2016
    63
    It's none res and the sounds not to loud on tickover it's a nice rumble so won't wake the neighbours on a morning, there's a few videos on YouTube with vxrs with exactly the same set up on as I'm having fitted on Friday, having intercooler fitted Saturday then just wait for shaun of sm tuning to map it
    28th July 2018
    449
    Sweet getting the same front pipe at some point
    Got the cobra non res cat back 3" on the way at the min in the post
    Got the toyosport 2.5 decat and precat delete on at the min to mate with cobra when it arrives but like you want the sport cat instead, the double decat is just temporary thanks to my original exhaust kicking the bucket at the worst time possible was going to get a custom made one but didn't have the cash at the time my original one broke
