Results 1 to 10 of 15
Thread: Wheel Alignment
    27th March 2018
    157
    Default Wheel Alignment
    Hi guys,
    Just looking for a bit of advise, I need two new tyres as my rears are very worn. I'm going to put my fronts to my rear and put two new tyres on the front.
    I had all my wheels balanced/aligned a couple of months ago and the car drives perfectly right now. My question is, if I put two new tyres on the front and move my current front tyres to the rear, am I going to need to have everything aligned again? Or will it be ok?
    Sorry for the noobie question, first time really having to go through the whole procedure of changing tyres lol
    VXRed blooded Andyb712's Avatar
    28th July 2018
    473
    Yes no two tyres are alike even from the same batch each one is a bit different if you don't do it your new tyres won't last very long you will get excessive wear on one edge depending on if they are towing out or in
    Even more so given the fact your last alignment was a few months ago your tracking has probably already moved due to potholes speed bumps etc
    27th March 2018
    157
    Quote Originally Posted by Andyb712 View Post
    Alright cheers mate, so I should get all four tyres tracked?? How much should I expect to pay for that?
    23rd May 2013
    2,461
    What - you recommend having wheel alignment done everytime you change tires?
    Thats just madness and a tremendous waste of money!
    I agree that tracking may have drifted out over time but really people get too hung up on wheel alignment...unless its stupidly out (to the point you can actually see it standing in front of the car) you'll easily burn through new tyres due normal mileage/wear-tear rather than from alignment being out. Seriously.
    Add to the fact the OP only had it done a few months no way should anyone be telling him to blow another £60 to have it done again so soon.
    28th July 2018
    473
    £60? I pay 25 at local tyre shop most places charge 30
    On a cheap run about with 14's on maybe i'd agree but for the price of vxr tyres I would not risk ruining them for the sake of trying to save £25-30 thats a false economy to me
    Even more so considering our tyres average at around £125 each
    Even budget brands are around 70 each
    And for clarification are we talking hunter hawkeye with printout etc or laser alignment because im saying laser alignment not hawkeye
    Are you VXR enough? Nurburgring 223's Avatar
    16th May 2012
    914
    Most places offer a free check anyway so no harm getting it checked!
    Astra VXR GTC, Summit White, Aero Pack, Performance Seat Pack, AFL's, Sat Nav, Climate Control, Tints! SOLD
    27th March 2018
    157
    Yeah I guess I'll get it checked and then maybe look at getting it re-aligned depending on that. Currently torn between the vredestein ultrac vorti and the Eagle F1 asymmetric 3...
    23rd May 2013
    2,461
    Its £50-60 for 4 wheel alignment most places up here, and has been for many a year.
    if you can get it free or for for £30 then perhaps its an idea.
    I personally wouldn't bother spending the money or time if the car is behaving itself..."for clarification" i fit my own tyres and do my own alignment and even on wheel alignment has never been a real issue after changing rubber, even on lowered cars.
    I'm just not into flushing money away for no reason.
    Suggestion to the OP: why not fit your tyres and run them for a few weeks? It should be fairly obvious from looking at the tread and how the car drives if it needs alignment
    28th July 2018
    473
    If you pay that then fair enough can see why your reluctant to spend it if I'm desperate my mate at vauxhall does it on Saturday mornings for £10 but i guess I'm lucky in that respect
    But as the op has said he is getting decent quality so I would do it no doubt
    But at the end of the day he can make his own mind up now he has a few opinions to go off
    VXR enough Jon1796's Avatar
    24th August 2015
    1,637
    Your lucky £100 for that down here then it doesn’t drive straight so gave up and do it myself instead.
