Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Wheel Alignment
  1. #11
    27th March 2018
    142
    Yeah thanks for all the opinions guys.
    I think it'd cost me about £60 to have all four aligned. So I'm not too sure what I'll do, but I'll give it some thought
  2. #12
    VXRed blooded Andyb712's Avatar
    28th July 2018
    449
    Quote Originally Posted by Bunni View Post
    Like suggested see if they will check it for free after the new rubber
    Most only charge for adjustment
  3. #13
    27th March 2018
    142
    Quote Originally Posted by Andyb712 View Post
    Yeah I'm fairly sure they do
  4. #14
    28th July 2018
    449
    Your lucky £100 for that down here then it doesn’t drive straight so gave up and do it myself instead.
    Jeez can get full hunter Haweye for £150 in the northwest full 4 wheel alignment digital readout and print out
    They do everything castor, camber etc full works like they do at the factory when new
  5. #15
    VXR enough Ant21's Avatar
    29th September 2013
    1,507
    I rotate my tyres every 6 or so months to promote even wear.
    Not once have I ever got a wheel alignment done when I rotate, only upon replacement.
    I've not had a single tyre wear unevenly and each time it's gone in for an alignment it's only been out by < half a degree, but generally still within tolerance.
    Think of that how you will, but I wouldn't personally throw in an alignment every 6 months. Pointless IMO.
