Results 1 to 5 of 5
    14th March 2019
    15
    Default Boost cut on Astra J VXR! Please help!
    Hi Guys,
    I bought my 15 plate VXR around 2 weeks and twice the car has completely cut boost. Its happened after a bit of spirited driving, its like the turbo has been completely removed when it happens. It does not feel like its trying to boost - it feels like there isnt a turbo!
    If I pull over and turn the car on and off this seems to the issue. Does anyone know of any particular reasons this would be happening? or things I should check/look for?
    Thanks guys!!
    VXRed blooded vocky's Avatar
    5th April 2015
    322
    I had a similar experience, which was caused by the maf sensor not being correctly plugged in after replacing the air filter element
    So it could be a faulty maf or a bad connection, might be best to have the ecu read for any stored codes before spending any money.
    14th March 2019
    15
    That's my thought actually, with only happening twice, where is the map sensor located on these? Cheers mate
    Sent from my SM-N950F using Tapatalk
    VXRed blooded imac's Avatar
    27th July 2015
    493
    on the pipe behind air box
    BUZZ BLUE GTC VXR mid life crisis & loving every minute.
    14th March 2019
    15
    Quote Originally Posted by imac View Post
    Legend, cheers pal
