Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    31st August 2018
    14
    Default Running extreamly rich
    Hi,can anyone help my vectra vxr is running so rich it chokes the engine and will not run.All plugs are firing but they are extremly sooty,fault codes are multiple misfires but on the front three cylinders only.So far i have changed both lamda sensors,maff sensor,ecu has been checked,exhaust downpipe leak fixed all vac hoses checked for leaks.Timing chains and gears were changed about 3000 miles ago,it started with a lumpy tickover then gradually got worse to the point that it will not run,there is also a rattle on start up has anyone got any ideas as to what could be the cause?
    VXR enough V6spike's Avatar
    18th May 2013
    1,849
    First call would be coil packs mate. If you swap the fronts and rears (a PITA) and the codes follow then there’s the problem.
    What codes does it bring up? Is the car mapped?
    Are you VXR enough? Andyb712's Avatar
    28th July 2018
    752
    Start with the coilpack as mentioned above
    But given everything you have checked if the coilpack doesn't cure it, i would be looking at the timing chain
    It could have been installed 1 tooth out or the tensioner could have been poorly adjusted and caused it to jump a tooth when running
    Only takes one tooth out to throw everything completely out of whack
    Just my two cents and I may be wrong but it could be worth checking it out chains are more susceptible to jumping a tooth compared to belts
    Did the issues start not long after the chain change
    VXR enough Jon1796's Avatar
    24th August 2015
    1,706
    Who done the chains ?
    24th August 2015
    1,706
    Quote Originally Posted by V6spike View Post
    Where you been lol
    24th August 2015
    1,706
    Reading it again somethings come loose you’ll probably have strip it down again to see what’s gone wrong.
    I.e. guide rail or tensioner.
    31st August 2018
    14
    Codes are multiple misfires detected on front three cylinders,the car has not been mapped.
    31st August 2018
    14
    Quote Originally Posted by Andyb712 View Post
    No,engine ran perfectly for about 18 months
    31st August 2018
    14
    Local garage done the chains (cost me a fortune)
    24th August 2015
    1,706
    Best advice sir nick150 I reckon something has come loose round chains, so you’ve got the rattle and misfire.
