Results 1 to 4 of 4
    VXR enough Hayden_93's Avatar
    4th January 2014
    1,236
    Default Actuator / recirculating valve
    Hi all as most of you may know Iím on my way to stage 3 is it worth upgrading both of them or just leave them both whatís your thoughts thanks a lot
    25th September 2013
    1,095
    I have been stage 3 for ages and both mine are standard never had a problem , do have a new forge valve but never bothered to fit it, only upgrade if you have a failure on one of them.
    stage 3
    4th January 2014
    1,236
    Quote Originally Posted by nippyrascal View Post
    Cheers man
    15th May 2013
    17,936
    Quote Originally Posted by Hayden_93 View Post
    Leave them Malcolm.
    Mine was Stage 3.5 with a standard recirc. It did split but replaced it with another standard. Had noting but grief with the Turbosmart one.
    As for actuator Iíd have probably made better power at Stage 3.5 with a standard actuator as the Turbosmart one I had was too strong and I ended up with valve float.
