Results 1 to 5 of 5
    2nd August 2012
    37
    Default Front a rear badge removal
    Hi guys looking to take my Griffen badges off so I can spray them black any one know how to safely remove them ?
    VXRed blooded vocky's Avatar
    5th April 2015
    338
    The front badge is just clipped to the grille.
    The rear badge is stuck on with double sided tape to a body coloured round disc, so a blast with some hot air and careful use of a blunt implement should get it off.
    2nd August 2012
    37
    Cheers vocky does the front one just pop off then ?
    VXRed Andre's Avatar
    1st July 2011
    174
    Nick its clipped in be careful not to break the clips/pins otherwise you will need some no more nails on the back of the badge when you put it back on, it will have pins that will push onto the grill backing so make sure you pull it towards you and not off at an angle
    2nd August 2012
    37
    Cheers Andre.
