Results 1 to 10 of 19
Thread: Boot won't open
    VXR enough corsaopc's Avatar
    28th August 2008
    1,048
    Default Boot won't open
    The boot will not open at all...all the other doors open fine....any ideas whata gone wrong the boot latch knackered i thought maybe.
    CORSA VXR & NISSAN 200sx Turbo!!!!!
    Nissan running at 260+ BHP !!!!! bye bye ST!!
    1990 Starlet GT turbo project ! running Subaru WRX turbo !
    28th August 2008
    1,048
    Would this be the solenoid? can the boot be opened from inside once the rubber plugged is removed and turned witha screwdriver?
    VXRed dan813's Avatar
    14th December 2008
    44
    This happened to my last car which was an astra design, the rear electrical box went. or it could be fuse.
    28th August 2008
    1,048
    Central locking seems to working fine but the boot.....no noise coming from boot once key is pressed.
    I wanted a yellow tint, not a perm! - Moderator vxrdave's Avatar
    18th April 2006
    14,631
    do the windscreen washers still work.
    VXRacing ahead DrG's Avatar
    21st January 2008
    547
    Quote Originally Posted by vxrdave View Post
    as above if the windscreen washers do not work either then it's fuse number 8 (red 10A mini blade) under the bonnet if i recall correctly....
    --gone--.
    28th August 2008
    1,048
    The windscreen washer pump has packed up as well....checked the fuse for the pump and its blown.
    Mr Franks.... dannyf's Avatar
    9th December 2007
    7,836
    when windscreen washers go pop so dose the boot
    just a mini fuse to fix it 27p DIY dead easy
    the truth is out there
    part GSI part VXR
    15th June 2008
    3,906
    this is common in the cold. I herd from vauxhall that it freezes then pops the fuse because it doesnt come out or something. person said leave 5 min before using the pump when its freezing cold
    28th August 2008
    1,048
    So the the chances are that when i replace the blown fuse for the washer pump then the boot will open when the key is pressed.
