Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
    24th September 2008
    2,485
    Default Legal Exhaust Noise Limit?
    whats the legal limit for exhaust noise?
    in terms of Db?
    Brett
    VXR Torque of the Devil BO55 VXR's Avatar
    23rd May 2006
    6,609
    On the road, there is no defined limit.. but you could be pulled if playing in an anti-social way (i.e. revving the nuts outside your neighbours house)
    On a track day, usually 95dB, some tracks have hi-limit days which is 100 - 105
    I get a Buzz out of life! moosh's Avatar
    3rd August 2008
    9,731
    Quote Originally Posted by VXRBrett View Post
    in terms of Db?
    Brett
    I was told it was 88.
    BTW i was charge with a previous exhaust and had to remove it.
    Theres a law about fitting an aftermarket exhaust which increases the noise from factory.
    Was up in court 5 times for it and in the end gave in and removed the exhaust and put a standard one back on...
    VXRacing ahead Bryan's Avatar
    8th December 2008
    568
    The legal limit across the UK is 101dba measured at between 2/3 and 3/4 maximum revs under load apparently as per the sva.
    You could no doubt be done for noise pollution at lower levels in the right circumstances.
    3rd August 2008
    9,731
    Quote Originally Posted by Bryan View Post
    whats the difference between dba and dB?
    I think its huge because 105 dB is instant deafness.
    24th September 2008
    2,485
    what is the difference?
    8th December 2008
    568
    Truth be known I have no idea
    I looked it up a few months back and remember the info, wasn't really helpful to me in any way.
    24th September 2008
    2,485
    so is it roughly 100db?
    8th December 2008
    568
    Thats what I've always taken it as, don't know if there is any difference between db and dba.
    8th December 2008
    568
    Planning on something loud then?
