Results 1 to 10 of 12
    15th February 2009
    44
    Default Vectra Indicator Bulb woes!
    Can anyone tell me how to change the front drivers side indicator bulb on my 2006 Vectra VXR?
    The manual lists instructions for nearside bulb replacement but for offside it says take to dealer!
    I have had a look with the airbox out and access is pretty limited
    1st November 2008
    1,297
    As above removing or loosening the bumper .... if your mechanically minded about 15 mins to remove
    VXR Giggle Control Disorder
    5th July 2008
    3,735
    15 minutes ?
    Far far easier way to remove is to unscrewn the vacume hose from the airbox. This enables you to push it back out of the way, and comfortable get your hand down there.
    Whats more its only a couple of jubilee clips as opposed to a whole bumper !!
    Obviously on the other side you remove the screenwash filler neck to enable you to get in.
    1st November 2008
    1,297
    Quote Originally Posted by MrLOL View Post
    15 minutes ?
    Everybodys different buddy , just find it far easier to remove bumper and yes...15 minutes
    5th July 2008
    3,735
    Quote Originally Posted by DavieK View Post
    my point was taht removing the vacume hose takes less than 1
    15th February 2009
    44
    Thanks for your responses. I have already tried with the airbox and hoses removed so will try with the bumper off
    16th June 2009
    15
    Guys help appreciated, im trying to change the n/s indicator bulb Vectra VXR 06 plate, removed the battery cover and washer bottle neck slackened off the top of the bumper and removed the 2 screws that are on top of the head lamp housing and i still cant seem to get enough purchase on the damn thing with my fat chubby fingers and i dont know which way to turn it or is it a pull out fitting, the book refers me to the main dealer sod that for a laugh, cars in bits hoping for a quick responce. Thanks in advance.....
    Dabs
    Spoke to soon, now I've crashed and burned vxr-bandit's Avatar
    4th January 2009
    22,938
    Right mate you have too take the bumper off if you cant get in mate, a couple screws in each wheel arch and a couple across the top of the bumper( think there is 3,)
    Then the light units come out mate, be carefull as you may need too adjust the heights of the lights afterward but no major problem,
    If you have something too sit under the bumper then just flex the bumper forward onto this
    HTH, any problems give me a PM
    29th April 2009
    201
    All this to change a lightbulb, life use to be so simple !
