Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    14th October 2009
    19
    Angry Major dump valve issues!
    Hi all,
    Just fitted a bailey dv (correct twin piston one) and I've only driven the car three times since and I've got the engine management light on (the Amber car with the spanner)! Also it seems to be "leaking" boost pressure when cruising at 70/80.
    Can anyone shead some light on this and if not has anyone got a spare STD pipe that the courtney sport one replaces as it tore when removing it.
    Thanks in advance for any help.
    Henry
    VXR enough AndyReinlo's Avatar
    28th October 2008
    2,792
    the spanner light can be reset by discontecting the negative from battery for 10 mins, this should also fix limp mode if u have it. as for the bosst leak, you will need a stiffer spring in the DV. and you can buy a blanking plug to replace the dump valve which means you wont have to source a new hose
    Corsa VXR - 18's, AFL, Sight+Light, ECC - FLAME RED
    De-Badged, VXR Grill Badge, VXROnline Stickers, ITG Filter, 6k Xenons
    25th April 2009
    65
    I have the same dump valve and had no problem at all.... i did change the DV to the collins but as soon as i did that i got limp mode aswell. I changed it back to the baileys and its been fine and i've now done 3000 miles with no problems.....
    When it 'Dumps' is it short & snappy ? or long & weak ?.... Because mine is really short & snappy but the collins was long & weak (like it was dumping to much )
    If you got it from courtney give them a ring and i'm know they will look at replace the faulty DV
    21st April 2009
    416
    you need to make sure you get the DV26D like the one in my sig, it has the stiffer spring already fitted and the DV26 doesn't.
    as Andy said, you can buy a bung to block the dumpvalve take off if you need to.
    Don't wish to hard turtle boy!
    26th March 2009
    1,833
    Hello mate if your after a bung i got 1 from ebay 380161334044 (list no)
    fits really well and had no probs, just use the metal screw clip that came with your dv to secure the bung
    hth
    21st August 2009
    290
    took my off today running stage 3 and the cars much faster bugger the dumpvalve!
    21st April 2009
    416
    Quote Originally Posted by stevevxr1 View Post
    didn't you just post in another thread saying it made your car faster?
    14th October 2009
    19
    Smile
    Quote Originally Posted by Mabnkat View Post
    I got it from a performance show down here, not courtney direct. It's fairly short but I do think the stiffer spring is a gd idea though. Easy to change the springs?
    Cheers for the advice
    14th October 2009
    19
    Smile
    Quote Originally Posted by AndyReinlo View Post
    Going to try that batt disconnect tonight chap. Not that I don't believe you but is it all ok when u disconnect the battery? No immobiliser problems or anything silly like that?
    Henry
    14th October 2009
    19
    To all on this thread.
    Thank you all for your help, really thought I had buggered up a perfectly good car a was starting to c""p myself about it!
    Just been on the phone to Regal Motorsport in Southampton and they do a stage one remap which gives no power increase but allows dv's and other after market products to work fine with no stupid warning lights! think it's around £250? Not too steep I think?
    What do u all reckon?
    Henry (Smithster)
